Aion 2: Complete Guide to Defeating Enraged Reda
Todos los temas relacionados con los desperfectos.
Daños a la entrega, desperfectos de uso, etc.
aBigAILClARK319
Understanding the Fight
Reda’s combat is split into two main phases:
Phase 1 – Direct Combat:
In the early stage, focus on dealing consistent damage while avoiding his telegraphed AoE attacks. Reda hits hard, but he’s manageable if you keep moving and dodge carefully.
Phase 2 – Summon Madness:
Once his health drops to 50%, Reda starts summoning mobs continuously. These aren’t simple fodder—they have normal HP and hit hard. If you ignore them, your healing will be overwhelmed, and the fight will spiral out of control.
Core Combat Strategies
1. Manage Summoned Mobs Immediately
Target the adds as soon as they appear.
AoE or crowd-control abilities are invaluable here.
Letting them stack is a quick way to wipe, even with high-level gear.
2. Animation Canceling for DPS Classes
Classes like Assassins can weave LMB and RMB attacks to cancel animations.
This increases your damage output and helps you burn down Reda faster, especially in Phase 2.
3. Avoid AoE Attacks
Reda telegraphs large AoEs, especially during Phase 1.
Don’t rush into him—focus on dodging, timing your attacks, and staying out of danger zones.
Preparation Checklist
Before engaging Enraged Reda, make sure you’re fully prepared:
Power Shards: Press B to confirm all shards are active. They’re essential for maximizing your damage.
Potions & Scrolls: Have healing potions ready and equip offensive/defensive scrolls to boost your stats.
Skill Allocation: Double-check your Dwanian skills and general skill points for your current build.
Gear Score: Use your best golden gear from expeditions or conquest dungeons. Standard starting gear often isn’t enough.
Pro Tips
PC Advantage: Players report that Reda’s mob phase can be tricky on mobile due to lag. If possible, tackle this boss on the PC client for more precise movement.
Pacing Matters: Don’t go all-in on damage. Focus on survival first, then chip away at his health safely.
Know the AoE Indicators: Learning Reda’s tells for AoE attacks can save you from massive damage and potential wipes.
By keeping control of the adds, dodging his AoEs, and maximizing your DPS with animation canceling, Enraged Reda becomes a manageable fight. With preparation and patience, you can defeat him and claim the rewards without breaking a sweat.
