Difficulty Modes:
Exploration: Easier, recommended for practice runs.
Conquest: Standard/hard mode for serious players.
Party Size: 1–4 players. Solo is possible if GS is high.
Entry Requirements: Level 45, Gear Score 2,200+.
Boss Guide
Boss 1: Watchdog Quapo
Quapo is highly mobile and uses electrical attacks. Constant repositioning is key.
Lightning Strikes:
The boss summons lightning bolts across the arena. Avoid the impact zones and pick up the dark orbs left behind. These orbs give important buffs.
Roar Wave:
After jumping, Quapo releases a wave outward. Jump over the wave to avoid damage.
Tips: Keep moving, collect all orbs, and watch for the jump animations.
Boss 2: Necromancer Dwanka
Dwanka is stationary but dangerous, using area denial and summoning adds.
Minion Phase:
Dwanka summons waves of adds. Group and burn them down quickly, or the healer will get overwhelmed.
Teleport & Blast:
Look for ground markers to see where the next necro-blast will land. Keep moving to avoid these attacks.
Tips: Healers should stay at range, DPS should focus adds immediately, and the team should spread out slightly to reduce AoE damage.
Final Boss: Ferocious Horn (Nuakum)
Nuakum is the most challenging encounter, combining heavy physical attacks with arena-wide mechanics.
Charge & Stun:
Nuakum targets a player and charges. Use defensive skills or dash to avoid the stun.
Enrage Phase:
At low health, his attack speed increases. This is when you should use scrolls and food buffs like strength, absorption, or critical hit scrolls to finish the fight faster.
Tips: Keep cooldowns ready, watch your positioning, and communicate orb and charge mechanics with your party.
Preparation & Tips
Gear Check:
Aim for GS 2,200+. If you’re stuck around 1,500–1,700 GS, use Pantheon Statues and Transcendence to boost power before attempting Conquest mode.
Consumables:
Carry movement speed and absorption scrolls to survive high-damage phases. Potions for health and mana are mandatory.
Loot Management:
Nuakum Armor sets are top-tier, but watch out for Soulbinding, which makes stat re-rolls expensive. Prioritize pieces that complement your class and role.
Quick Tips Summary
Collect orbs and avoid AoE waves.
Burn adds fast during Dwanka’s minion phase.
Keep moving in Nuakum’s arena, especially during charge attacks.
Use scrolls and food buffs before enrage phase.
Check your GS and optimize your equipment before Conquest runs.
Following this guide, even a small group can efficiently clear Ferocious Horn Den and secure the coveted Nuakum Armor. Keep practicing mechanics, coordinate with your party, and you’ll master this endgame dungeon in no time.
