In Old School RuneScape (OSRS), the Dragon Defender is one of the most coveted items, prized for its substantial defensive bonuses and decent offensive stats. It provides one of the best combinations of defense and attack bonuses in the game, making it invaluable for combat in a variety of situations. Whether you're tackling PvM (Player versus Monster) content, engaging in PvP (Player versus Player) combat, or completing Slayer tasks, the Dragon Defender is a versatile and sought-after item.
But how exactly do you obtain the Dragon Defender in OSRS? Getting the Dragon Defender requires a fair amount of effort and time, and it all begins in the Warrior's Guild, a minigame-like activity where you can earn the tokens necessary to participate in the Defender grind. In this guide, we'll cover everything you need to know about how to get the Dragon Defender, including the requirements, the process, and some helpful tips along the way.
Step 1: Meet the Requirements
Before you can even start working towards the Dragon Defender, you need to meet a few important requirements:
1. Combat Stats
To participate in the Warrior's Guild and eventually earn the Dragon Defender, you need a solid combat setup. Specifically, you will need:
70 Attack
70 Strength
These levels are not strictly mandatory but are highly recommended. While it is technically possible to grind the Dragon Defender with lower stats, it will significantly slow down the process. The higher your Attack and Strength levels, the faster you'll be able to kill the required monsters in the Warrior's Guild, which directly impacts how many tokens you can earn.
2. Quest Requirements
To access the Warrior's Guild, you must have completed the "Dwarf Cannon" quest, which unlocks the ability to use a Dwarf Cannon within the guild. This quest is relatively straightforward and requires some basic combat training, but it's a prerequisite before you can start grinding for the Dragon Defender.
Additionally, it is highly recommended (though not required) that you complete the "Animal Magnetism" quest. This unlocks Ava's Device, which is a helpful tool for gathering Warrior Guild Tokens and improving your chances at acquiring a Dragon Defender.
3. Warrior Guild Tokens
To engage in the activities of the Warrior's Guild, you need Warrior Guild Tokens. These tokens are spent to participate in the minigame activities where you can earn the Dragon Defender. You'll need a significant number of tokens, so you'll need to prepare a decent cash stack to buy them.
You can purchase tokens with coins at the Warrior's Guild, and the cost per token varies depending on the activity. Be sure to have a steady supply of coins or a method to generate them.
Step 2: Enter the Warrior's Guild
The Warrior's Guild is located in Burthorpe, just west of the Burthorpe lodestone. Inside the guild, you'll encounter a variety of different activities and NPCs that you'll need to defeat to gather the required Warrior Guild Tokens.
The most important aspect of the Warrior's Guild is the Defender's Room, where the Dragon Defender is eventually obtained. To access the room, you need to meet a few conditions.
1. Killing NPCs in the Warrior's Guild
The primary way to earn Warrior Guild Tokens is by killing different NPCs inside the guild. You can defeat either Attack or Strength based monsters (or both) to earn points. The Cyclopes, Warriors, and Guardians are the most popular enemies to defeat for tokens.
2. Using a Cannon
Once you've completed the Dwarf Cannon quest, you can use a Dwarf Cannon inside the Warrior's Guild to help you kill the NPCs faster. The cannon allows you to kill multiple monsters at once, significantly improving your token-gathering efficiency. This is especially useful for higher-level players who can afford to use it in a more sustainable way.
3. Tokens Accumulation
Once you've killed a monster, you'll receive Warrior Guild Tokens. The exact amount of tokens varies, depending on the monster you defeat and how well you perform during the battle. It is essential to accumulate a large amount of these tokens since each attempt to earn the Dragon Defender requires a substantial investment of tokens.
RSorder provides a simple and affordable way to buy OSRS Gold and RS3 Gold. Click here to find out about our great deals on Runescape Gold.
