U4GM How to Use Gear Artificing Without Wasting Materials
Todos los temas relacionados con equipamiento.
Acabados, extras, etc.
Hartmann846
Acabado: Black Edition
Color: wrire
Estado: Procesando pedido
Provincia: Girona
After you clear Wuling, the Gear Artificing menu starts tempting you to click around, especially if you're already comparing drops or even browsing Arknights endfield accounts to see what late-game builds look like. Still, this system isn't there to rescue weak gear. It's for polished gold pieces that are already worth keeping. Think of it less like upgrading and more like tuning. You're not changing the item into something new. You're nudging one stat higher, bit by bit, so a strong setup gets even tighter in actual combat.
How the core loop works
The process is pretty simple once you stop overthinking it. First, pick the gear piece you want to improve. Second, choose the sub-stat you care about. Third, spend a regional Catalyst and feed in another item from the exact same slot. That's the part a lot of players mess up at first. Boots need boots. Gloves need gloves. On top of that, the sacrifice piece has to reach the stat requirement tied to your target upgrade. So no, you can't just dump random gold junk into the machine and hope for free value. The game clearly wants you to make choices, not spam attempts.
Why failures aren't as brutal as they seem
Artificing can absolutely feel rough when a roll misses. You lose the Catalyst. You lose the fodder piece too. Early on, that can make the whole feature look like a trap. But the hidden pity system changes the mood a lot. Every failed attempt adds progress to that exact stat on that exact item path, and once the bar is filled, the next upgrade lands for sure. That doesn't make it cheap, though. It just means bad luck won't spiral forever. In practice, it's smarter to save your materials and work on pieces you know will stay in your build for a long time.
The value of high-roll fodder
One of the easiest ways to waste resources is ignoring the Good Match bonus. If your sacrifice item has a better base roll in the stat you're targeting, your success rate gets a lift. That's huge. It means those awkward gold drops with one unusually high stat and awful everything else aren't actually trash. They're fuel. You start looking at your inventory differently once you realise that. A bad helmet with a great ATK line might be exactly what your main piece needs later. A lot of experienced players keep a stash for this reason, and honestly, it's worth the bag space.
Where your resources should really go
If you're trying to get real value out of Gear Artificing, put your effort into the operators that carry your damage or unlock key support breakpoints. Don't spread materials across every item just because the option is there. Most of the time, defensive padding isn't worth the cost when you could be pushing a set's main scaling pieces much harder. Pick one or two anchor items, build around set synergy, and only then start chasing cleaner stat lines. That's when the system feels good, and it's also why some players who buy Arknights endfield account setups still end up refining gear by hand, because the real edge comes from those small, targeted upgrades that match how a character actually plays.
