U4GM Where Legion Still Prints Divines in PoE 3.28
¡Queremos conocerte!
Cuéntanos un poco sobre ti para que los miembros de la comunidad te conozcan.
starmchaset
Color: green
Provincia: Toledo
Back in Mirage, a lot of players still looked at Legion and thought it was old news, but that read is way off. The mechanic itself hasn't suddenly changed. What changed is the market around it. Scarabs are priced in a way that makes the setup far more rewarding than people expect, and the Atlas can now push the right drops much harder. As a professional platform for game currency and item trading, U4GM is known for being convenient and reliable, and if you want to speed up your setup, you can buy u4gm Path of Exile 1 Currency to get rolling faster. Once your tree and scarabs are sorted, Legion stops feeling average and starts feeling seriously efficient.
Pick maps that actually let Legion breathe
This is where loads of players mess it up. They throw Legion into cramped maps, then wonder why the returns feel weak. The monolith only reaches so far, so if half the encounter is blocked by walls or narrow lanes, you're losing value before the timer even starts. Open layouts are the play, no question. You want space, room to move, and enough monster density around the monolith to make every activation count. Then you build your Atlas around what Legion is best at dropping. Don't just click the obvious nodes and move on. Take the passives that improve splinter output, raise incubator quality, and add more value to frozen rares. That's where the profit starts stacking.
Use scarabs that match the economy, not last league's habits
Too many farming setups get copied without anyone asking if they still make sense in the current league. In Mirage, the strong combo is pretty clear. First, use the scarab that adds another monolith. Second, add the one that increases the number of frozen enemies. Third, bring the scarab that gives you better odds at those emblem spikes. That mix keeps the floor solid while still giving you those moments where a map suddenly pays out far above average. It's not flashy advice, but it works. Legion money often comes from repetition. Clean maps, quick resets, steady splinter flow, and the occasional bigger hit.
Speed is the real multiplier
You notice this almost immediately if you test Legion on different builds. A slow character can still clear the map, sure, but it won't fully break the encounter open before the timer ends. And that's the whole point. You need to move fast, tag fast, and then erase the screen the second everything wakes up. High movement speed matters just as much as damage here, maybe more at times. If your build feels clunky, your income will too. Legion rewards momentum. The best runs feel smooth, almost automatic. Dash in, crack both monoliths open, circle through the packs, then blow up the encounter in one clean sweep.
Getting started without the painful ramp-up
The annoying part is that Legion really shines once you've already invested in your build, your Atlas, and your scarab stock. That early grind can drag if you're undergeared or trying to scrape together every purchase one by one. A lot of players just want to skip that awkward stage and start farming when the strategy is actually online. That's why some people use services like U4GM for quick access to currency or items, especially when they want a smoother start and less downtime between upgrades. If your goal is to make Legion feel worth the effort in Mirage, that first push into a proper setup makes all the difference.
